OK, turned on my stamina bars and I STILL cant get a sub without giving a serious beating first!!!
I can take my opponent down and mount but his stamina just sits there while he outpoints me punching from the bottom!! I can either block punches or block transitions (although the transition block looks like I'm saying "please hit me!") but either way I cant get his stamina down!!!
Can anyone tell me for sure what actually constitutes a "strike"??? Am I allowed to knee whilst in side mount or elbow maybe???
I just cant see how to get a sub without hitting the other guy with SOMETHING!?!?!?
StevieP
sidemount is probably the best way to tire someone, so i'd go for that, he will try and reverse it by sitting up, block it a few times in a row and his stamina will drain to zero. Slap on a kimura, although it can still fail if you have a low sub attack I think, probably if he has high sub defence or strength too.
I tried sidemount but without me actually doing something, the other guys stamina just sat there!?!?
StevieP
That's strange, when i play the guy on the bottom usually tries to escape, which causes his stamina to die. I'm playing on expert though.
I believe it's something like 40 fights and then you're forced to retire... not 100% sure though!anyone know how many matches you have to play before a career is completed? or if not when a career ends?
Never mind!! I've sorted it and got the trophy!
StevieP
How did you sort it? Did you have to have the downloaded fighters or had you just missed one out..?
