Argh.
Does anyone know how to get shortcuts into the startup folder in the start menu? Im on 7137 and can't do it for the life of me.
Right click on startup, explore, drag shortcut into windows.
Argh.
There is a quick launch, its just not there by default. Search this thread for a post by me on how to do it.
Or Google it !!There is a quick launch, its just not there by default. Search this thread for a post by me on how to do it.
Cheers i'll give that a try.
Another question now :
Is anyone using a compro videomate E700 PCI-E tv card with win7 64 bit?
I'll be wanting to use media centre with it![]()
I have been using build 7201 for a few days and for some reason its slower
then 7100 and it wont let me install Intels new drivers for my P35 mobo which Build 7100 would.
I.E I run the installer for Intell on build 7100 and the drivers are for 2009
I do the same on build 7201 and they stay at 2008 even if I try to force the update.
So I am going back to 7100.
Anyone else using 7201 and back up these claims?
Did anyone else have trouble installing 7100?
I pick the drive, set the language then it gets to the part where is says the percentages and just sits at 0% on the first one. I waited 10 mins and it didn't move.
I downloaded it again and burnt the DVD at 1x and still had the same thing.
Sorry to post this guys but I'm a little bit confused
I'm not sure which version to download.. and where to download from!
I'd like to do a fresh install onto a new HD at some point today/tommorow and would be v.grateful if someone could point me in the right direction
System is running a Core 2 Duo E8400 & 4GB of Ram (I believe this helps you figure out if I need X86 or X64?)
Thanks
