- 24 Apr 2004
- Warrington, UK
Hi all,
For those that don't know my 200SX has suffered big end failure as a results i have set about the task of rebuilding the engine with forged internals with a hope to achieving 400bhp and a similar amount of torque eventually.
The intial spec will consist of the following
86.5mm oversized CP Pistons 8:5:1 CR
Manley Rods
Greddy Valve Springs
Horsham Developments Type 1 Head Rebuild
1.9 Metal Headgasket
Mazworx Head and Main Studs
New Oil Pump Internals
Nismo Engine/Gearbox Mounts
ACT Heavy Duty Clutch with Fidanza Flywheel
G28R Ball Bearing Turbo from a S15
After this i will run it as it probably circa 280bhp two reasons for this let the engine run in and i wll be flat broke by then. But when i get more money i will invest in the following
18" / 9" wide rims
DB Power Big Foot Brake Kit 360mm 6 pot Brembo Calipers
300ZX rear brake setup
Apex Type 2 Coilovers
Front and Lower Upperbraces
Subframe locking collars.
After all the above i will be going for broke
GT3071R Turbo flows enough for 450 i think not sure
Nismo 740cc injectors
Horsham Developments Custom Map.
This thread will be a diary of events and my progress as i go along hope you all enjoy. Day 1 is after this post.
Cheers
Daz
Manley Rods
18" / 9" wide rims
Cheers
Daz
