Yeah. One 260 will be give or take as fast as a single 9800GX2, so two will be about as fast as two 9800GX2s, without the SLi issues or heat.
Well i had SLI 8800GTX's ( about the same speed as a 9800GX2 ) and i swapped them both for a GTX 280. I was pretty unimpressed really although i did have less of a room heater afterwards. in most cases the GTX 280 was slightly slower than the SLI setup, so a GTX 260 certainly will be.
I think if you went from SLI 9800GX2 to SLI GTX260 youd be dissappointed really
Wait, if an 8800GTX is the same speed as a 9800GX2, and he has two 9800GX2's, then that means his setup is similar to yours. If you went to a single 280 and noticed a slight performance drop, surely that means that SLI 260's should be an increase in performance?
If you could afford sli 9800GX2's why doesn't he get a 295gtx? possibly two of them
A 260GTX can be made to run the same speeds as a 280GTX and wityh two of them would effectively be twice the performance of SLI 8800GTX or 9800GX2. Of course it never works that way, but is therotical. As sli 8800GTX = 280GTX.
:EDIT:
Oo i didn;'t see he had two of them. I suspect sli 280GTX is still faster then sli 9800GX2 tbh.
Yeah - crazy.Go for it, I can't believe they're willing to do a straight swap.
I currently have 2 9800gx2's but quad sli has never worked properly
