"Back of an hour"
Im thinking the back of five means before the hour hand on a clock hits 5, therefore around 4.50-5. Never heard it before though.
As said above its a scottish term meaning after 5 ie 5:00 - 5:15
This.
It means just after the hour. So if you finished your work at 5pm and lived nearby you'd be home "at the back of 5". Typically it only goes to quarter past the hour though, as then you're getting too close to the half hour mark.
It's a Scottish expression, English fiancee took a while to get use to it as she thought it meant before the hour.
The only way I can explain it is if you think about your car and your talking about the car parked behind yours - it's the car "at the back of" yours. Hence it being immediately after the hour erm the car, god I need a drink.
It really should be "bottom" of the hour, which would be 5:30 - 5:59. "Back" sounds dumb. Just like an inning in cricket, I would think. (edit: do they call it that?)
Well by most people's logic if you're adding minutes, you're stacking them and they're getting higher - so it'd be top of the hour ? :p How can you add something and get lower?
Ahh, but if I'm taking the minutes away from those remaining in the hour, the stack will be getting lower. :p Like sands in the hourglass....
That's a retarded expression.
This seems fitting, also.
