Spec me a MP3 Player for cycling...
Sansa Fuze or Sansa Clip.
I have the Fuze and it's really great. Got it for 49.99inc and it has 8gb internal memory and a 4gb miniSD. Very good sound quality as well.
The clip is even smaller and might be a bit better for cycling.
£20 - £60
LOL. :D (unless you're looking for something 2nd hand????)
the maximum capacity you'll get for that budget is 8gb. a sansa fuze as mentioned above is around 60 sheets for 8gb and has a slot for expansion. or a sansa clip may be more suited for your intended use. it's tiny and that costs 40 quid for 8gb. has no expansion slot though......
edit: beaten. :p
thanks for the suggestions, ive been looking and a lot these days have mp4 games and things, i just want a simple mp3/fm radio player with decent amount of song storage. im not paying for the extras i wont use!!
ill check out them sandisk and sansa suze ones out cheers!
Fuze will be best choice as you can put memory card in to increase the memory.It is also small, comfortable for cycling.
For me, i use Shure E5Cs coupled with loud music, so basically I can hear sweet-FA... makes crossing the road a scary experience :D
Certainly wouldn't want to cycle like that lol
