***The Official Infamous Thread***
Btw does anyone else wish the climbing etc was a bit more fluid? I hate having to mash the X button to get to the top of buildings. I dont think I truely appreciated Assassin's Creed till now..
I would have liked it if you just had to press up instead yeah. But to be fair, as mechanics go, this game has done a really good job imo.
[EDIT] Just finished it, can safely say i did not see that plot twist coming. Can't wait for the sequel!
AH for christs sake, 346/350 shards...
One of mine was on a pier I swore I'd checked. Other usual suspects are the one on the bridge between Historic and Warren, the destroyed pier in the north east of Neon, the top of the tall building directly north of the blast crater.
Do you have a count of how many you had when moving between each Island ? there's 147 Neon 135 Warren and 68 Historic (counting the one on the bridge between Warren and Historic as Historic).
I've actually got most of the obscure ones i think, it's just i didn't really search when running around the city so they're probably scattered around. I do find it puzzling that i completed a mission and was given 5 blast shards but they didn't add to my total.
I was on that mission with the balloons.I got to the last balloon and the game froze.Had to reset and it started me right back on the first island:mad:
They add to your total for getting new battery cores but are not part of the 350 "in the wild" that count towards the trophies.
Ah, i see.
348/350, running out of places to look, all i can do now is scour the entire map i think :(
Have you checked the one out at Sea? Go to Zeke's hideout and then it is out at sea just after you pass the first train station form his hideout (clockwise).
You can even see it when you are grinding the train tracks, but it is too far out to appear on your map at that point.
The amount of freezes and lockups I have had with this game is ridiculous. I am sure otehr people are having this too, or my 60GB is on it's way out :) Only does it with inFamous so I blame the game.
rp2000
I would backup now and sign up for continuous play if I were you.... The game has been absolutely fine on my 80gb...
rp2000
Aye i've got that one
349/350 :/
found an easy way of getting the 5 melee kills within 30 seconds, near the beginning of the game when you are trying to get across the bridge with zeke, just lay into the coppers at the gate.
Ok did the Have a Nice Fall stunt in the Dark Water missions. Nearly all of those have 3 Reapers on a roof, although it took a few attempts to line them up.
Now I am on stunt 19 of 21 (no idea what the other 2 are): "Right Back at Ya". Any tips? I can sometimes get an enemy to eventually throw grenades at me if I dodge around him for a while, but I dunno how to aim the grande back at him.
If I am at a distance should I be aiming at the grande while it is in the air coming to me or wait till it lands? Seems like it would be hard to aim it back exactly.
Any specific points where grenade throwing people appear consistently?
rp2000
rp2000
I hid behind things and waited for them to get bored of me being behind cover and lob a grenade. I just spammed shockwave after the throw and was lucky after about four or five tries. Also don't use movable objects as cover for obvious reasons.
Last stunt is the lightning storm one about throwing an enemy in the air then hitting them with a storm.
Use your shield zap them a couple of times then wait for them to throw a grenade, not sure but i think if you wait till the 3 island you can try those floating bots as all they do is chuck grenades.
