Hi
I have had my car check by two garages one was my local garage and one was Nissan dealer.
My car a few days ago is lacking in power almost like I am towing something.
It pulls ok from 0.30 ish ok but after that when you start to notices the power loss,on a long straight road I can get the car to up around 65-75 but that's it then the car keeps changing gear as its struggling to accelerate.
the main dealer could not find a fault with the car aftter they plug it into there computers but did a reset on the ECU and also reset it to re-learn mode?
I have no warning lights on the dash and been told its possible autobox problem but seems abit unlikely at 38K and on a 04 plate car.
Also been told could be the mass air sensor.
Is there any body around who has had this problem or is there an expert on Nissan as I don't wont to be changing parts for the sake of changing them.
also to add the gear box seems fine changing gears revs little bit high but think that's down to the lack of power when trying to accelerate
also revs fine in neutral
