Logitech G15 or Saitek Cyborg?
8 Jun 2004
As topic says. Which keyboard is the preferred by people here? Im stuck between choosing which.
Also thinking of getting the Logitech G9 mouse.
G15 the cyborg looks fugly. The g9 is a good mouse, had mine nearly 2 years now and its going strong, recently got a new cover for it and it looks brand new again.
CYBORG ;-)
Out of preference i have a cyborg because the 'gamestation' in HMV Manchester uses G15 and i dont like them. The keys on the cyborg feel more like a regular keyboard, that perfect sortof amount of noise, spring back etc but very responcive.
They both proform just as well, it depends what you prefer the feel of, and if you want a lil screen that shows you your ammo...but you have to look down off yor screen to see it insted of the bottom right of your screen :-s
Or if you want funky lights?
The gamer keys on this side of the cyborg have a very nice feel and are useful, i pretty much use them for RTS' as i can never remember all the keys on the keyboard at a glance so just have them set as home, auto build etc going down.
Can you display temps and fan speeds and things like that on the G15, coz i bet thats pretty useful, only use i can think of for a screen realy.
yes you can display temps and load of anything and everything on it, just have to get the right app. Not that i use mine beyond the default cpu/ram load.
G15 is my preferance, noisy keys suck tbh. prefer my g5 over a g9 though, but not used the g9 fo rlong enough to get used to it so that might be it
Wow thats a lot of replies :)
thanks all. G15 it is then i guess!
OR am i likely to want 18 bind keys which the G11 has :)
Are they useful or is 6 on the G15 enough?
Cool, suppose its a good choice for the overclocker in mind.
THe keys aint noisey, they just aint rying to be silent, where they have a that unnatural keyboard sound...if you know what i mean?
Both are good, but if your planing on OC'ing then the 15 sounds a plan.
(cyborg still looks awsome ;) )
