Hi all,
I've done a couple of searches via Google and PGAC, but can't really find anything.
My mum owns a 2000 (X) 306 HDI, and went to have the air-con re-gassed.
The guy said he couldn't re-charge the system as it was leaking, and would replace the pipes providing she bought them.
The 2 pipes are quite common to go according to results on Google, they run across the front lower part of the car (behind the front bumper).
According to the A/C guy, the pipes are...
-Compressor to Condenser Discharge Pipe
-Compressor to Service Valve Suction Pipe
Any help retrieving part numbers would be great, or a point in the direction that i can get the part numbers
Thanks,
Phil
Thanks,
Phil
