- 20 Mar 2007
- Norwich
I want to get a power rack and stick it in my bedroom.
Firstly, is it safe having that much weight on an upper floor? I assume it'll be fine because the weight is spread quite a lot.
Secondly, can anyone recommend one which is small and can, if possible, be used with a barbell smaller than 7ft. The smaller the better as it'll be going in my bedroom which isn't exactly gym sized!
Budget wise. Under £400 definitely, but preferably under £300.
If you could also recommend a bench which will incline and decline under £150 that'd be very helpful too!
