Been looking for the 1.6kg tubs of SiS Go Electrolyte Lemon & Lime flavour powder in my local Tesco store. Going by the Tesco website it shows that the 1.6kg tubs can be had for £16.49 which is a very competitive price.
However, I've been in 3 local Tesco stores, one of which was a "Super-Tesco" sized one and all I can find on the shelves are 500g tubs for £7.50 which isn't a great deal compared to the 1.6kg size.
Asked the staff about the larger sized ones and was met either by a shrug of the shoulders or a "I dunno mate?" response.
Has anyone found the 1.6kg packs in an actual Tesco store or is it the case that if its on the Tesco Direct website then it can only be had mail order in that size?.
Cheers for any replies.
That should make about £50 worth of your GO Powder
