I have a pc which I am fixing for someone which has the following symptoms:
When power button is pressed, you get a short few seconds of power (fans spin up) but then it cuts out and you dont get nothing..
I dont think its the power supply as I have tested another power supply in this unit and get the same problem (a known working power supply) so Im pretty sure its deffo the motherboard.
Is there another way I can test before I say (yep its your motherboard).
