The question is so broad and encompassing that it is virtually impossible to answer. Why don't you try and answer it yourself......
It's not broad and encompassing. It was made in the context of the current debate. You're smart enough to know what it means; don't try to dodge it by retreating into pedantry.
Look, I'll even make it easy for you:
What are your views on multiculturalism?
What are your views on immigration into the UK?
What are your views on the integration of different races and cultures into British society?
Off you go.
Incidentally I'm unlikely to respond to "demands" from you. "ANSWER THE QUESTIONZZZZZZZ". Think of a short pithy sexual retort and consider it headed your way.
So after all the bluff and bluster, this is where it ends: a panicked dash to the door. I wonder why? Is this simply moral cowardice? Don't you even have the conviction to define and express your own beliefs?
In a previous post, you said:
I prefer to base my opinions on facts than just spouting emotional guff
You also said:
My views? What are my views? I have yet to express any.
So... what are your views and opinions on the issues of immigration, racial integration and multiculturalism?
