Agreed, but I don't really have much of a guide to what they should actually be? Any ideas?
So, I re-applied the Arctic silve 5 using the instructions on their website (let the heatsink do the movement, don't scrape it over yourself) and get better values:
Stock Speed, Stock Cooler
idle: 36C
load: 72C
Huge improvement.
Still goes over 100C at 3.0GHz though![]()
just a small note guys, you should be able to run a co 920, with a good cooler on 3.4ghz turbo on, at 1.20volts, and defo on a DO spec chip, just manually adjust cpu volts as auto, always overvolts, MY CO 920 ideles with a TRUE extreme @ about35 to 40 @ 3.4ghz with 1.20 volts, , saying that ive got a collermatser cm storm sniper case with a few extras fans than normal, but always manually adjust volts never auto when ocing.
Hi all,
Just put in my new Core i7 920 D0 and getting surprisingly high temps at stock.
This is a retail chip with the stock cooler on it.
At Stock speed, idle is ~50C and Prime95 load puts it to 87C
When I oc'd it to 3.5GHz, Prime 95 put the temps over 100C and the machine shutdown.
I took off the thermal paste on the chip and replaced with arctic silver 5, but similar sort of issues..
Is this normal sorts of temps, or am I doing something wrong here.
MB is Gigabyte UD5
Cheers!
