- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Last year Coolermaster designed and produced a Cosmos Black Special Edition with a 850w Power Supply and a Hyper Z600 CPU Cooler, all of which were entirely finished in black. Exclusivity was assured due to a limited production run of only 500 units. Due to popular demand from our customers, Coolermaster are producing a brand new Cosmos model with a full black interior and exterior, giving the chassis classic looks that will stand the test of time. With a vented side panel, space for all the latest high end hardware and the cooling performance to match, the Cosmos Black pushes the boundaries of high end case design. Be the envy of your friends with one of the most exclusive and stylish pieces of hardware currently available.
- Soundproof materials applied to build a quiet environment
- Sound barrier design reduces vibration for silent operation
- Dual bottom air intakes to enhance air flow and reduce system noise
- Six aluminum detachable HDD modules with ventilation holes for optimizing cooling
- Side removable VGA cooling tunnel to advance thermal airflow
- Patented finger pressing buttons for quickly maintaining or upgrading 5.25” drive
- Tool-free design for opening side panel conveniently
- Separate HDD modules make it easy to organize
- Cable management system for better cable routing and neatness
- Motherboards E-ATX, ATX,
- Cooling System
- 5.25" Drive Bays 5 Exposed (without the use of exposed 3.5" Drive bay)
- 4 Expose (with the use of one 3.5" Drive bay)
- 3.5" Drive Bays 6 ( Hidden ) ; 1 Exposed (converted from one 5.25" Drive Bay)
- Front I/O Panel USB 2.0 x 4, IEEE 1394 x 1, Audio x 1, SPK x 1, eSATA x 1
- Bottom fan ( intake ) :120x120x25 mm x 1, 1200 rpm, 22 dBA (included)
- HDD fan : 120x120x25 mm x 1 (optional)
- Rear fan : 120x120x25 mm x 1 (included)
- Top fan (exhaust) : 120x120x25 mm fan x 2, 1200 rpm, 17 dBA (included)
- (W) 266 x (H) 598 x (D) 628 mm
PRE-ORDER for only £179.99 inc VAT.
