Finally managed to find two of these to buy for my radiator.
Fan Size: 120mm x 120mm x 38mm
Speed: 2600 RPM
Airflow: 102.5 CFM
Noise: 39 dBA
Static Pressure: 64.7Pa (~6.6mm H2O)
Bearing: Ball bearing
Voltage: 12 V
Current: .52 Amp
Power: 6.24 W
http://www.madshrimps.be/?action=getarticle&number=10&artpage=4136&articID=936
Most people judge fans on cfm when the important figure for radiator cooling is static pressure IMO.
Just thought I would share the fact that I have two of without doubt, the best radiator/case 120mm fan you can buy (performance vs sound) arriving soon
Speed: 2600 RPM
Airflow: 102.5 CFM
Noise: 39 dBA
Voltage: 12 V
Current: .52 Amp
Power: 6.24 W
