as some of you may have seen in my recent build log/overclocking threads
i currently have a Biostar Tpower X58
i am happy with the board as it does 224 BCLK and runs everything i want it to
although it wont run my 2000mhz memory at the rated speed because the divider will not work
i now also have a Rampage Extreme 2
this is a board with much better support and a more comprehensive bios
there are some tasty Koolance full cover blocks for this board that match my GFX card blocks, the REII will certainly look great in my TJ07 [its too big for my fortress]
however - im worried it will not clock as well as my biostar
i know its stupid to concern myself with overclocking past 4.5GHz but i cant help thinking that my P6T deluxe was a bag of fail and this might go the same way
its not going to be one of those 'what board should i get' threads
i would just like to know which everyone would choose out of the two if you had both
and then share your thoughts, I'm sure plenty would also like to know blonde or brunette. If you get rid you might regret, I would keep both and have a threesome.
