Its about time I finally replaced my old bargain-basement 80mm fans for some newer, quieter ones, but not too sure what to get now days...
As topic says, my case is a CoolerMaster CM201, which has room for 2x 80mm in the front, an 80mm exhaust in the back, plus an 80mm in the "roof" of the case.
Not sure whether to have the 2 front fans with more CFM than the exhausts, to give a slight ammount of positive pressure in the case, to hopefully stop it pulling dust in from around the panels etc.. given that the PSU Fan is also drawing air out aswell.... Reckon its worthwhile, or just over-thinking the situtation and best to just get 4 of the same fans?
And with that in mind, any recommendations? Im not looking for an ultra-silent PC, but on the other hand, I dont want it to be screaming like a banshee either, so can you good people spec me a good choice of fan(s) with nice airflow, but not too much noise?
Thanks all
Thanks all
