Afternoon folks,
Have a bit of an issue,
Got a customer which has a HP Proliant 330 Generation 3..it only has USB 1.1
The tape drive seems to be giving up which is a SCSI one and ideally I wanted to install a USB one, however the HP one I found is highspeed USB 2.0..
Im sure it will work on 1.1 but will be deaaaaaad slow!
Now im thinking of getting a PCI Expansion card for the customer so I can install this card internally with 2.0 slots and bang my problem solved...
Only issue is all the internal cards I see have compatibilities for everything but Windows 2003 SBS Server..
I dont want to take the risk just getting it as I am going onsite to install a new tape..
Has anyone had same issue or can recommend me a USB 2.0 Expansion PCI card thats compatible with the Windows 2003 SBS os...?
Thanks a much
I dont want to take the risk just getting it as I am going onsite to install a new tape..Has anyone had same issue or can recommend me a USB 2.0 Expansion PCI card thats compatible with the Windows 2003 SBS os...?
Thanks a much
