Can't run IBT
24 Jul 2006
Essex
I've downloaded IBT countless times and every time I try and run the program I get the message 'This application has failed to start because the application configuration is incorrect. Reinstalling the application may fix the probelm'. It's not like I can reinstall it as it's not installed in the first place!
I've tried a few places but generally from guru3d.com, the notes don't suggest that there are seperate versions for 32bit and 64bit anyway.
Yes, its the .exe in the root that should run pick the correct version of linpak to run.
Unsure why it isn;t.
What version are you trying to use?
Windows fully up to date?
Just done 10 runs on standard settings with ibt, passed successfully. As im currently on xp home 32 do i have to manually select the amount of ram i wish to test, as standard doesnt seem to use all available ram.
Select 'custom' and then enter the value as the maximum amount of RAM that you have available.
I had the exact same problem when I first tried to use IBT, do what Big.Wayne said, that will sort the problem...
