i climbed the north face of the eiger
picture of most recent attempt
Altitiude sickness is horrible. Drink lots of water it helps. Also, you burn easily up there. I normally dont burn and I burnt in 2 minutes with factor 50 sun block on :/
But cheers, will keep it in mind
Thanks for the post D.P. Do you know who your friends used and if they would recommend them? Will see about the Chamonix thing. Might be more hassle than it's worth (visa etc since I don't have a UK passport)
I'm Indian. natural sun blockBut cheers, will keep it in mind
Did it years ago, it's just a long walk until the last camp where altitude can get you. The guides call it the "coca-cola" route. I puked and got severe headaches, even though I was fitter than most.
We didn't use anyone in particular. Just local porters. The land rover ride to the start was awesome. Our Land Rover rolled on its side!!!
The flights are expensive. Cant remember the price but I think mine was about 600. We flew by emirates![]()
If you fancy doing it for a good cause, check this out
have a look here
A fantastic experience
..might even get to meet wayne rooney
They turned up and found a local guide.
www.SummitPost has some info and contacts.
Kilimanjaro is on my to do list. I really want to do it, but I'd want to do it with a friend or two to share the experience. It really does look amazing.
You could be blacker than black you can still burn so be careful.
Altitude is a bit wierd though, I had some major problems with it in Nepal and Tibet and was very fit at the time (was 18 and was a decent x-country runner, did plenty of climbing etc..).
you can try taking diamox tablets, drink plenty of water etc... do an acclimatisation trek first.
I thin these days you can get special tents to sleep in before you go which basically starve you of oxygen and simulate the effects of being at altitude.
A personal friend of mine, Henry Stedman, is THE man. He's probably sold more books on the subject than anyone.
Check his website out at http://www.climbmountkilimanjaro.com/
Though tour operators, it differentiates between the types and pros and cons, but not so much with names etc. Any chance you could ask him if there's any particular operator (s) he would recommend?
