It's out Wednesday, around 19:00 GMT I believe. You can download and play the beta right now, but it's buggy and laggy, so it's best to wait.
I pre-load from STEAM, is that BETA?
Hmmm does anyone know if i have the beta would i need to also dl the other pre-load to be able to play, as i just tried to log onto the beta and says license information failed validation.
The beta and full game are seperate d/ls.
why couldnt they just patch the beta client so it can be used as normal.Thats a kick in the teeth, means another large downloadwhy couldnt they just patch the beta client so it can be used as normal.
If you have pre-loaded this on steam then go to your steam folder and locate where it has installed to then double click the EXE from there, people are playing it now that have pre-loaded.
It works for some, then others it dont. So it's worth a try
(C:\Program Files\Steam\steamapps\common)
Although, anyone remember the Killing Floor launch? - lol - Never known a bunch of fanboys get soo wound up.
The timer says:
Available: 17 June 2009
This game will unlock in approximately 1 day and 6 hours
So, 20.00 tomorrow evening.
