Street Fight IV PC-Benchmark Released
That lag is caused by the way the game synchronises all actions rather than using a GGPO rollback style system. Nothing to do with the rendering of the game.
I'd explain it in detail but it takes so long to type it I really can't be arsed :p
Quite remarkable how well this benchmark does on old hardware:
Running at 2.7gig
SCORE: 5829
AVERAGE: 57.00FPS
OS: Windows Vista(TM) Ultimate
CPU: Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz (Actually 3.8 w/ no HT)
Memory: 6134MB
Graphics Card: NVIDIA GeForce GTX 295
Display Setting: 1920x1080 60Hz C16xQAA
A little low for me tbh.. gonna update my gfx drivers :)
SCORE: 5829
AVERAGE: 57.00FPS
Memory: 6134MB
Why no HT, what's the point?
All max...
SCORE: 9669
AVERAGE: 121.50FPS
OS: Windows 7 Ultimate
CPU: Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz
Memory: 4096MB
Graphics Card: NVIDIA GeForce GTX 285
Display Setting: 1280x1024 60Hz C16xQAA
out of interest, just try it with c16xAA just to see if it runs? not after you posting the results.
Yep, it does run. Not as bad a framerate either if i'm honest (45FPS) i get less than that with 2xAA in windowed mode so clearly running it fullscreen boosts performance somewhat.
Clocked down to 3.6 and enabled HT.
Updated drivers to 185.85 (whihc inceidentally are lagging for some reason)
SCORE: 8961
AVERAGE: 119.87FPS
Memory: 6134MB
Display Setting: 1920x1080 24Hz C16xQAA
I'm happier.. just need to sort out the windows lag.. my mouse feels horrible :(
Edit - Sorted lag so its a BIG :D from me :)
Rank: A
SCORE: 6413
AVERAGE: 63.98FPS
CPU: Intel(R) Core(TM)2 Quad CPU Q9450 @ 2.66GHz
Memory: 4096MB
Graphics Card: NVIDIA GeForce GTX 260 (Prerelease - WDDM 1.1)
Display Setting: 1920x1200 60Hz 2xAA
(c)CAPCOM U.S.A., INC. 2008, 2009 ALL RIGHTS RESERVED.
Everything on high/highest, V-sync OFF, cpu @ 3.4Ghz, gfx @ stock.
It actually had a slight flicker which was noticeable but this is sorted once V-sync is ON. If I can play this at the highest settings @ 1920x1200 I will be pleased! Looks so much better then what I am use to seeing on the PS3. :)
Opteron 165 @ 2.8Ghz
8800GT @ 720gpu 1800shader 975mem
1920 x 1200 fullscreen
All settings on High
VSync Off
4 x AA
4 x AF
Anyone else got an older rig to compare this against? :cool:
VSync Off
4 x AA
4 x AF
Thats a nice result.
[QUOTE='[timko]...[/QUOTE]
That's not bad at all. Infact, it seems v impressive.
What drivers are you using? I notice you are using Win XP, wonder if that makes any difference.
SCORE: 8961
AVERAGE: 119.87FPS
Did you just enable HT (and reduce CPU clock by 200mhz in the process) and update your gfx drivers and go from average 57fps to 119fps?!
If so thats amazing, what a difference!
Or maybe you also turned vsync off?
I'm using the latest non-beta of 185.85. I think my result only looks good because it's posted right after yours. There's something holding things back on your rig for sure, you should be a lot closer to the 100fps mark with vsync being off :)
Just tried something else. I turned off AA in the actual benchmark settings, but switched to 16XQ AA and 16X AF in the nvidia control panel, and noticed it actually ran a lot smoother.
SCORE: 7858
AVERAGE: 59.85FPS
Memory: 4096MB
All settings HIGHEST
16XQ AA
16X AF
V-sync ON
It ran smooth with absolutely no slow downs during any ultras or the character part at the end.
