Quick question regarding my motherboard. I'm currently using an Asus 4870x2 on this board along with an Asus Xonar D2X in the normal layout - GPU in PCI-E slot 1, sound card in PCI-E slot 2. In the manual it states if you put a single GPU into slot 2 it will drag it down to a 4x slot, but can I run with my GPU in the second slot and sound card in the first without performance loss? The reason I want to do it is the sound card is so close to the face of the GPU that it's running far hotter than it needs to because it can't get enough cool air in.
If I can't do it on this board are there any that can? Any other solutions that would help are also appreciated, basically getting an increase in idle temps of around 10°C on the GPU due to this.
