- 9 Sep 2008
- Glasgow
4GB is sufficient for most power-users and gamers.
Hey Mattus,So if your games are 32-bit, they can't use more than 2GB of RAM, even if you're running 64-bit Windows.
Thanks for the link Stonedofmoo, that seems to confirm what Mattus said!Chris Angelini-Tom's Hardware said:remember that a 32-bit application without /LAA enabled is still limited to 2 GB of virtual address space, even in a 64-bit environment. However, we’ve seen plenty of examples of technical gamers modifying executables to turn the large address aware flag on.
Yeah I know what you mean, the prices are amazing!Personally if I was building right now I would put in 8......just because it's so cheap.
I am just about to put my order in at OcUK im going for the amd x3 720 black edition with a Gigabyte GA-MA790XT-UD4P what I want to know is 4gb of memory enough or should I get 8gb will be running vista 64 ultimate System is going to be a gaming machine
Thanks
2Gb for the OS, 6Gb for the RAMDrive - sweeeeeeeeet! Definitely worth £28 if you can be bothered to set it up properly!![]()
because it's a waste of 28 quid
