Hey mates,
Does any of you use HomePlug AV adapters? (200mbps) Perhaps Edimax's?
I've this problem, tell me if it's ever happened to you:
I purchased two units of Edimax HP-2001AV, plugged the first in then the second, and everything worked properly. (Speed indicator was RED, meaning not so great, but it was enough.)
An hour later I wanted to switch one of them to another socket, for perhaps it would yield better speeds, so I unplugged one of them and plugged it in another socket in the same room, but from that point it was never in sync with the second unit. No matter what I tried (reset button, leave and rejoin a group button, plug it in the socket it once worked from.) it ceased syncing.
I sent the units back to store and it sent me two new units.
I plugged them in the sockets, everything worked properly again. Then, two days later I had to rearrange my room, therefore had to unplug one of the units. After I had finished rearranging my room, I plugged the unit back in the socket, and guess what?
It ceased syncing again.
What the heck is it?
Edimax itself is pretty useless, telling me it's either my own mains or the units have again dropped dead.
Has anyone of you ever experienced such a situation?
Do you know of any compatibility problems HomePlug might have?
Thanks and cheers.
Thanks and cheers.
