http://www.overclockers.co.uk/showproduct.php?prodid=GX-131-XF
As title, seems a good price & I seem to recall it is the shader clock that has the most impact. My current 8800GT 256MB won't run SETI & runs up to 84C with the 511 pointers but have got that down to 79C with Riva tuner. I think a lot og the "unstable machine" & "Nans detected" is down to heat - although I've had a bad run yesterday.
The only flaw I can spot is that the card is long at 266mm.
There is another GPU on the horizon so should I wait for that? I've heard that some of the 200 series have a whine due to capacitors or something.
Almost forgot - I have a 620w PSU (SLi) with an o/ced Q9550. Will that be enough for the new card?
Thanks
Thanks
  and silent
