Silent keyboard
Softer touch keyboards such as Cherry are quieter but not silent which for me is ideal as I find loud keyboards annoying but need the feedback as andi mentioned.
I can recommend this which I am using now :)
By silent keys do you mean the type you find on a laptop (sissor keys)? I'm typing on a Logitech DiNovo, and although not silent, its a lot quieter than normal keys and sounds totally different. It's also really thin, takes a while to get used to, but soooo much better than normal keys!
Thanks for the help. I am just looking for a keyboard that has soft touch keys. I am a really loud typer and its annoying, even to me. I am currently using a merc gaming keyboard and its awfully big. The gaming part of the board I don't even use, even when gaming. I like the gaming keys on the merc but found myself using the old qwerty keys instead. :D
That keyboard is a thing of beauty. I just must have it... but its abit pricy.
