I just orderd this Lian Li TR-3B LCD Multifunction panel
that's about as useful as the tiny bit of info ocuk put on there website, what I wonted to know is dose any one have any feed back about it? dose the fan control work well, dose it tell the time well, dose it work well with every thing its meant to?
Surely you should have checked into these sorts of things before...you know...buying?
- Size: 3.5"
- Fan setup and display
- Fan speed control and detection
- Temperature available in Centigrade and Fahrenheit
- Icon display for power on / HDD access / fan speed
- Alarm for fan error
- 3 Temperature sensors
- 3 Fan detection
- 4 ICBM Type: Polaris
- 1 Uranium enrichment plant
it was cheep, and as I needed a 3.5 bay fan control with no big controls, and had no time to look in to it, before I payed I just had a shot in the dark, and wonted to know if any one had got one, so I could get some feed back.
but as I can see no one has any thing to say about it other than it dose what it said on the page.
well here is the link, you tell me what you think of the description.
http://www.overclockers.co.uk/showproduct.php?prodid=CM-006-LL&groupid=701&catid=1428&subcat=1429
and yes from time to time I like to impulse buy stuff hehe.
If it's like the one my friend has then my impresssion is that they offer little or no control and are fundamentally 'automatic'.
It's ok if that's what you want but if you do want to manually crank the fans up for a gaming session you won't be able to. :(
Can't seem to find any reviews - but will see if i can track something down.
gt
Edit: Looks to be fully auto like i suspected. Here's the manual - http://www.lian-li.com/v2/tw/product/upload/manual/C50.TR-30.00.pdf
and the current details page: http://www.lian-li.com/v2/en/produc...ex=287&cl_index=2&sc_index=33&ss_index=80&g=q
I've taken it off my order now any way, I would had to wait a week for it, and that kind of takes way from the hole next day delivery thing, thank all for the input, I'll be giving this one a miss.
dose any one else have any suggestions as for what's a good fan controller, that will fit in a 3.5 bay and has low profile dials, so I can close my case front, or even pop in pop out dials?
if the internal chronometer is not as good as that of a pc then yes it could be up to 30 seconds slower or even a minute, haven forbid, lol.
it was a bit of a stupid question, but at the same time I was just trying the get more feed back than what lukeTW was giving me.
