best upgrade with £200 budget...
17 Oct 2006
spec as is...
enermax liberty 500w power supply..
gigebyte GA-965p ds4 motherboard
intel core 2 duo e6300 1.86ghz
tunig tower cooler
geil 4gb 4 x 1gb pc6400c4 800mhz ddr2 memory
4 x seagate 1tb drives
ocuk geforce 7900gs 512mb
thinking of
http://www.overclockers.co.uk/showproduct.php?prodid=GX-091-PC or http://www.overclockers.co.uk/showproduct.php?prodid=GX-127-XF
and
http://www.overclockers.co.uk/showproduct.php?prodid=CP-272-IN
as the next best upgrades..
would people agree or suggest something different..
thanks for looking..
and is the card much longer than the one i have as space is tight in my case..thanks.
Unless I'm going mental I can't see your current card listed so would be pretty hard to compare size wise :p
Not sure if your motherboard can handle the 45nm chip? I have the same and I am sure last time I checked I could only go 65nm technology.
I am in the same boat as you, however motherboard is packing up. Just going to get a cheapo one, and save a bt more and go amd later in the year. Possibly worth just waiting a bit longer and save for a mobo/cpu upgrade.
From the dimensions I can find for 7900GS cards compared to the 4870/50's I think you are going to find it's a fair bit bigger. If you can measure the actual card you have it'll be easier to find out as it's nigh on impossible to find exact dimensions for the card you've got.
its 22cm long mate..
