ddr2 v ddr3
Permabanned
5 Jan 2008
Is A DDR3 System considered to be a big improvment over a DDR2 system ?
I am thinking of getting rid of my mobo and memory
Currentl setup
MSI p7N diamond 780i
OCZ RaptorX 1000mhz 4GB
Potential new setup
Evga 790i F.T.W
Corsair XMS3 DHX 1600mhz 4GB
What do you guys think ?
Currentl setup
Potential new setup
Evga 790i F.T.W
Total waste of time; DDR3 offers a very small performance increase over DDR2, so the only reason you should use it is if you have to (ie with Core i7 or an AMD DDR3 mobo.) The amount you'd be spending on a 790i board and 4GB of RAM would be better used elsewhere.
Aren't you supposed to run DDR3 in triple channel thus 6GB min?
DDR3 is available in dual channel or triple channel kits. Triple channel kits come in multiples of three, so you can run 3, 6, 9, 12gb etc.
I wouldn't bother tbh, the difference in day to day tasks is minimal to nothing between the two. Imo any motherboard upgrade should be to x58 so people can stop using the pos nvidia chipsets.
What's your usage?
Do you game?
Without knowing what it's for, I'd say the XFX one, as it's a better brand, the 512MB v 1GB wont matter unless you do anything specific really.
I don't game myself, so I'm not sure, but I don't think it really makes much difference even for gaming.
However you might want to consider a different card altogether, have you read Carbon's parts thread?
Because the 9500 gets a 0/10 from him, for price vs performance.
How about the 4670? There's one here and the 4670 is around the same price mark as the 9500, but Carbon gives it a 5/10 rather than 0!
The one I linked is from Asus, theres also one from Gigabyte, but it's a bit more expensive. Avoid the other ones though, they're from tackier brands.
