Hi all,
I dare say this would get an accurate response from Lashout, Lopez etc etc.
A brake pipe has perished (corrosion as far as i can tell) on the Mondeo.
I've looked on the Mondeo Forums and it seems its a common area for them to corrode (above the fuel tank).
I've only ever had one brake pipe go, and that was to a caliper so i'm not really that clued up on the brake lines themselves. A friend seems to think that the pipe can be cut and then joined with unions?
Does this mean that the particular section thats corroded can be cut out and replaced, rather than the whole pipe?
Is this a 'safe' way to do it, or more like a temp-fix?
Its going to be sat on the drive over the weekend but its in the garage next week to have the pipe done and then MOT straight after, so i'll need to tell them which method i want doing!
Cheers,
Phil
Cheers,
Phil
