It wont be any problem, just fill it to the top with diesel.
Agree with the above , brim it with diesel and itll be fine .... (itll run like a badgers arse for that tank)
[TW]Fox;14326939 said:This. Don't think its commonrail is it?
Would it be logical to assume that since diesel is more dense than petrol, and the outlet is at (or near) the bottom of the tank, it will see very little petrol - far less than you might suppose with a 10:1 ratio diesel to petrol - thus needing frequent topups for quite some time to lower the concentration of petrol to the point you can run the tank mostly to empty before filling up? Presumably only turbulence will cause the petrol to enter the fuel pipe.
Fill the car with petrol and it will 100% fine, trust me
