Please help with new spec
18 Feb 2003
My brother has asked me to build him a new PC for £500 and i'm a bit behind on todays components.
He plays Darkfall Online and CS:S, so it will be for games and ebay. He would like to keep XP, but i will go Vista if he needs to.
Thanks
does he need a monitor/keybpoard etc...if he does then maybe this is ok which is just over budget...if not then the second one is just under budget
OcUK Value X2220WMS 22" Widescreen LCD Monitor £119.99
(£104.34) £119.99
(£104.34)
Intel Core 2 Duo E7400 LGA775 'Wolfdale' 2.80GHz (1066FSB) - Retail £88.99
(£77.38) £88.99
(£77.38)
Asus ATI Radeon HD 4850 512MB GDDR3 TV-Out/Dual DVI/HDMI (PCI-Express) - Retail £78.99
(£68.69) £78.99
(£68.69)
Gigabyte GA-EP35-DS4 Intel P35 (Socket 775) PCI-Express DDR2 Motherboard £55.99
(£48.69) £55.99
(£48.69)
Corsair VX 450W ATX Power Supply (CMPSU-450VXUK) £54.99
(£47.82) £54.99
(£47.82)
Samsung SpinPoint F1 320GB SATA-II 16MB Cache - OEM (HD322HJ) £36.98
(£32.16) £36.98
(£32.16)
Kingston HyperX 4GB (2x2GB) DDR2 6400C4 800MHz Dual Channel (KHX6400D2LLK2/4G) £35.98
(£31.29) £35.98
(£31.29)
Asus TA-D31 Midi-ATX Case - Black (No PSU) £26.99
(£23.47) £26.99
(£23.47)
Samsung SH-S223B/BEBE 22x DVD±RW SATA Dual Layer ReWriter (Black) - OEM
if he dont need the monitor then maybe this
Intel Core 2 Duo E8400 LGA775 'Wolfdale' 3.00GHz (1333FSB) - Retail £126.99
(£110.43) £126.99
(£110.43)
Asus P5Q Intel P45 (Socket 775) PCI-Express DDR2 Motherboard £95.99
(£83.47) £95.99
(£83.47)
(£68.69) £78.99
(£68.69)
(£47.82) £54.99
(£47.82)
(£32.16) £36.98
(£32.16)
(£31.29) £35.98
(£31.29)
(£23.47) £26.99
(£23.47)
Samsung SH-S223B/BEBE 22x DVD±RW SATA Dual Layer ReWriter (Black) - OEM £18.99
(£16.51) £18.99
(£16.51)
Arctic Cooling Freezer 7 Pro CPU Cooler (Socket LGA775)
Thanks guys. Can XP handle 4g fine?
And are the AMD's better than the Intels now? The last time i was looking at a build, everyone was going for the intels.
With the core 2 and i7 has still got a very nice lineup. But for this budget, the new phenom 2 dual and triple cores beat the low-end intel core 2s and pentium duals.
I meant thanks to everyone:D
I got the same spec that siumatfung said but changed to the tri-core. What do you mean pics of the build? Pics of it in the stages of being built? I don't know if i could handle the pressure:(
Yeh pics of it being built and pics of it finally built.
Don't worry about the pressure, just take your time and you'll be ok.
I'll try and get some pics up. I hope nothings changed much in the last few years. The last build i did was a socket 754 with a 6800gt.
I'm gonna be sick giving it to my bro though, i might just shove my dell bits in his new case, he'd never know:D
