- 16 Nov 2008
- West Midlands
Is their a way of restoring windows to early date? restores back to 16th of june i need it to restore before that.
I have vista 64bit mate its in my sig.
That article tells you how to rstore i know how to restore i just wanted to know if it will restore past 16th of june.
How do I start System Restore?
• Open System Restore by clicking the Start button , clicking All Programs, clicking Accessories, clicking System Tools, and then clicking System Restore.* If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
NoteBefore you start System Restore, save any open files and close all programs. System Restore will restart your computer.
How do I choose a restore point?
System Restore automatically recommends the most recent restore point created before a significant change, such as installing a program. You can also choose from a list of restore points. Try using restore points created just before the date and time you started noticing problems.
How long are restore points saved?
Restore points are saved until the hard disk space System Restore reserves is filled up. As new restore points are created, old ones are deleted. If you turn off System Protection (the feature that creates restore points) on a disk, all restore points are deleted from that disk. When you turn System Protection back on, new restore points are created.
