CPU Cooler No Budget
The Titan Fenrir is very poor actually - very tight and too close to memory ram. The 1366 bolt under motherboard with screw is pretty poor as there is no screw on top of the nut to screw it down with a screwdriver, I had to use my thumb and finger to screw it very tight.. I got these with my 4Ghz oc bundles as the temperature went too high at 90C straight away.
Thermalright TRUE Copper :D
Optimus Prime says "NOOOOOOOOO!" :p
The Megahalems trumphs the TRUE copper in all but a few select reviews, and I believe its cheaper too. And it isn't mobo bending heavy either.
Isn't the v10 the current best on load if you heavily mod it?
Read a review a while back and it was way below the rest once tweaked with that engine they have.
