1200£ Budget - PC + 24"-26" Monitor
12 Feb 2009
Århus, Denmark
This is the first time I'm going to try and build a PC myself. I could use some suggestions from experienced fanatics!
I don't really have any preferences. Would be nice if everything fit in an Antec 300 though.
Will you help me? :)
Have I got this right? £1200 for the base unit and then the Monitor is separate? If so, then here's a beast of a system;
Monitor
Monitor
Thank you for the suggestion!
I was thinking £1200 for PC and monitor. But i think I'll be able to stretch my budget :)
You're right, that is a beast. Thanks again.
By the way.. Would the SSD be for the OS?
Oh right, I'll amend my spec then. Yes, the SSD would be for the OS.
This would still be a very good setup.
EDIT: I realised I forgot the PSU. The Corsair that Sycho listed would be good enough.
This is what I'd go with personally:
*OVERCLOCKED* Intel Core i7 920 D0 Stepping (SLBEJ) 2.66Ghz @ 4.00GHz / Gigabyte EX58-UD5 Intel X58 Motherboard / Patriot Viper 6GB DDR3 PC3-12800C8 1600MHz DDR3 Bundle + World in Conflict Game £539.99
(£469.56) £539.99
(£469.56)
Asus ATI Radeon HD 4870 X2 2GB GDDR5 PCI-Express Graphics Card Asus ATI Radeon HD 4870 X2 2GB GDDR5 PCI-Express Graphics Card £241.99
(£210.43) £241.99
(£210.43)
Samsung SM2494HS 23.6" Widescreen LCD Monitor (LS24KIVKBQ/EDC) Samsung SM2494HS 23.6" Widescreen LCD Monitor (LS24KIVKBQ/EDC) £218.49
(£189.99) £218.49
(£189.99)
Silverstone Temjin TJ04B Aluminium Tower Case - Black (No PSU) Silverstone Temjin TJ04B Aluminium Tower Case - Black (No PSU) £74.99
(£65.21) £74.99
(£65.21)
Corsair TX 650W ATX SLi Compliant Power Supply (CMPSU-650TXUK) Corsair TX 650W ATX SLi Compliant Power Supply (CMPSU-650TXUK) £73.99
(£64.34) £73.99
(£64.34)
Western Digital Caviar Black 1TB SATA-II 32MB Cache - OEM (WD1001FALS) Western Digital Caviar Black 1TB SATA-II 32MB Cache - OEM (WD1001FALS) £70.99
(£61.73) £70.99
(£61.73)
Pioneer DVR-216DBK 20x DVD±RW SATA Dual Layer ReWriter (Black) - OEM Pioneer DVR-216DBK 20x DVD±RW SATA Dual Layer ReWriter (Black) - OEM £17.99
(£15.64) £17.99
(£15.64)
Sub Total : £1,076.90
VAT is being charged at 15.00% VAT : £161.54
Total : £1,238.44
I didn't add a SSD because for any realistic use 30GB isn't enough capacity. You'll get the OS and maybe 2 games on there before you'll need to start deleting to fit more on. I don't know about you but I tend to have more than 2 games installed at a time so find it a pointless investment at the moment. If you really want a SSD though I'd go with:
Samsung PB22-J 64GB 2.5" SATA-II Solid State Hard Drive (MMCRE64G5MXP-OVB) £137.99
(£119.99) £137.99
(£119.99)
I would go Icey's spec but with the monitor i listed as it's probably the best 24 inch by quite a bit the only thing is it will be quite far over your budget but worth it.
