Street Fight IV PC-Benchmark Released
All maxed, cpu actually at 3.80 Ghz.
When I try and print screen all I get is black when I paste it.
Anyway, I got my new Arctic Freezer Pro 64 today so overclocked my 4200+ to 2.64ghz got a fairly good increase, my ranking is now A with the default settings!
SCORE: 9505
AVERAGE: 62.32FPS
OS: Windows 7 Ultimate
CPU: AMD Athlon(tm) 64 X2 Dual Core Processor 4200+
Memory: 4096MB
Graphics Card: NVIDIA GeForce 7900 GTX
Display Setting: 1680x1050 60Hz
(c)CAPCOM U.S.A., INC. 2008, 2009 ALL RIGHTS RESERVED.
Finally got a chance to benchmark on both of my computers, everything maxed out on each of them.
Main computer
and on my second gaming computer
I can't even get this to run! I can get to the main menu but as soon as i try to start the benchmark it just goes to a black screen :(
Spec is below before any one asks
AM2 6000+ @ 3ghz
8gb DDR2 PC6400
9800GT 512mb
Vista HP x64
Who needs
Heres mine, still love my 8800 gts 640, nothing it cant run :)
God knows why it has at the bottom you might want to run on higher? everything is maxed out.
E8400 WOLFDALE 3GHZ (OVERCLOCKED 4GHZ)
8 gig dominator corsair
Asus p5q
8800 GTS 640 MB
Thats with everything maxed out, if i do it on low apart from the 16x i get just under 29000.
what is everyone's favourite extra touch
i will probably leave it off but i i had to choose id say watercolor looks the best
Was anyone else a bit gobsmacked at how much better this looks compared to the console versions ?
Not really if you are playing on a console quite often you will be sat a tad further back than you would when playing on a PC.
At a distance they really don't look much different, PC looks a bit sharper but that's about it.
Also the game syncs frame by frame to the other persons client I think, so what happens if some reject is trying to play the game too high for his system and he's dropping below 60 constantly? :confused: I'd also be worried about hackers/macro users on PC when playing online.
I take it you are supposed to keep v-sync on for the game to play at the correct framerate?
With V-sync on the game looks like it is playing at the correct speed but is capped at around 60fps.
With V-sync off I get around 112fps but the game looks like it is playing at totally the wrong speed, everything is far too fast.
I also had this concern but apparently 'that's not how it works' according to Kreeee so hopefully it should be ok.
You gonna be getting the PC version mate? Would be good to start matching up against you again, even if you do destroy me :p
I might get it, I haven't played SF since the beginning of May now though. :p
SCORE: 8161
AVERAGE: 94.88FPS
CPU: Intel(R) Core(TM)2 Duo CPU E8500 @ 3.16GHz
Memory: 4096MB
Graphics Card: ATI Radeon HD 4800 Series
Display Setting: 1680x1050 60Hz 8xAA
Asus p5q
8800 GTS 640 MB
Something was not maxed out as your frame rate is higher than people with massively better GPU's. The list in settings goes down for quite some way.
OMFGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGG.............
Just ran this on my 50" plasma (i'm getting sick of seeing that typed now but I can't help it) at the following settings...
*1900*1080
*E6600 @ 2.4ghz (fanless)
*4870 1GB @ stock
*8xAA
*16xAF
*Everything to max and ink on
...and got a smidgeon under (58fps or something) 60fps average. Words simply cannot express how farkinffurking AMAZING it looked especially with vsynch. The picture was so pefect I thought I was going to get a fireball to the face.
**** me I think I need to go lie down, it's not healthy to love a TV this much...
I am so going to buy this game. :D
Aye. Will be good, tho only select ppl who agree no special fighting game hardware or macros. Keyboard (urgh) or a normal but nice joypad with no auto functions.
