Converting large HDDs to FAT32
30 Jul 2004
East Sussex, UK
Morning guys,
I need to convert a 500GB hard drive into FAT32. So that I can connect it to my Xbox 360's USB port and watch all my movies off there. At the moment I am transferring off the drive to a small 120GB twhich is FAT32 and is working ok.
Any ideas?
( I don't have a PC so can't stream off there to the Xbox. Just have a laptop. )
I'm pretty certain they're not http://support.microsoft.com/kb/314463
Microsoft think 8tb maximum, but windows won't format them to larger than 32gb
A gparted livecd will certainly do this for you, but is perhaps a touch excessive
If by convert you mean change to fat32 without losing the data currently on it you have a rather tougher job ahead, its far easier to reformat then copy data back on. Safer too
I think FAT32 partition sizes are limited to 32GB.
they're usable in windows over 32gb, but it doesn't let you create them..
i thought I'd read that the commandline option worked, if not, then just use parted magic boot cd, gparted is on it.
Morning guys,
Your best bet is to borrow another drive, back up, format your 500GB to FAT32 ( gparted ), copy the files back.
or
If your 500GB partition isn't full, you could try to shrink it, make a FAT32 partition in the freed space. Then, copy some files to the new FAT32 partition, delete the copied originals, enlarge the FAT32 partition.. repeat ad infinitum. However, there's a significant risk of data loss with this method e.g. power cut, shrink failing and causing corruption. It should only be used as a last resort.
I just use acronis disk director for such things
Its such a shame that xp wont let you format one more than 32G , I mean
why not ? It can read em , why not be able to set them up ???
Shakes fist at sky "Damn you bill gates!"
