Wrap a Stobart truck up in 5 hours.....
far easier to remember a name than a random collection of numbers and letters.
ironically, Stobart don't use vehicle registrations nor the names to identify their units, everything has a "Fleet Number"
Trailers are identified by numbers also,
http://www.eddiestobart.co.uk/Services/Transport/Technical_Specs.php
Double post! :o
Looks very good, good watching stuff done that you just don't think about, and I bet for you its like watching a date getting dressed! ;)
If you vinyl wrap, for example, a blue car in a full white wrap, do the DVLa need notify as it is a colour change, albeit temporary? Always wondered
The guy doing that is very good, the way he lines things up perfectly by hand is seriously impressive.
About the knife marks, if you do it right, it shouldn't touch the paint, you effectively score the vinyl most of the way through and then tear it along the line.
Does anyone know how much this type of thing costs?
I've been looking at getting my work vans done in a similar fashion, but they're only small (Berlingos).
I was quoted around £700-800 for the MX5 to get wrapped. So I'd imagine ~£1500 or so for a small - medium sized van to get done.
Very cool video.
This is a wrap, thought it looked quite cool (car is grey underneath)
That was on our ferry back from Lemans. We were wondering if it was wrapped or an expensive sprayjob as it wasn't a Porsche colour.
a lot will depend on colourings, i.e. whether your colours are off the shelf etc
After a bit of research, the DVLA don't need to be notified as it's a temporary colour change. Insurance must be informed prior to the wrap.
I would love to hear from somebody who has had the wrap removed and the result of adhesive left behind, knife damage and generally whether it's a viable alternative to a respray.
The only reason I ask, is because I really want a white/matte black car at some point... so would be able to find a tip top condition car that's well looked after in any colour, then wrap it to white for ultimate win :)
couple of guys on detailing world have had wrapped cars back with the wraps removed.
Adhesive is no harder to remove than the tar you find on your car. Just generally give it a good going over with APC and tar and glue remover.
As for knife marks, if the person doing it does the job properly, its nothing a quick going over with a machine polisher wont sort afterwards :)
guys on detailingworld that do wrapping say just treat it as normal wash wise. Just obviously you cant really polish it.
You can use a paint cleanser like lime prime or swissvax cleaner fluid via a machine polisher on slow setting if you want to. Not that you'd need to though, since its vinly not paint.
I've not got any first hand knowledge myself, all that i know is from reading on detailingworld
Mainly from threads like this
http://www.detailingworld.co.uk/forum/showthread.php?t=118883
and this
http://www.detailingworld.co.uk/forum/showthread.php?t=119228
You'd be surprised how many Stobart drivers polish the wrapped trucks.... :D
As for cleaning, the wrap stands up to steam cleaners & pressure washers, the biggest problem is air bubbles that tear.
http://forums.overclockers.co.uk/showpost.php?p=14325066&postcount=20
Here's what happened when the guy with the Porsche took his vinyl off
Also had a few knife marks apparently.
