Computer starts but won't boot up Windows
5 Apr 2008
Deepest, Darkest, Essex.
A mate has a PC that starts up normally until it gets to the Windows starting screen. Then it goes back to the beginning and does that over and over.
Can anyone tell me what's knackered? I figured HDD, but I took that out, put it in my machine and I can read it fine on my PC. Didn't try booting from it mind!
No, I must confess I didn't try to do anything with it. Just opened the folders to make sure the info was still there.
No RJC, 'fraid not, it didn't give me the option.
Didnt give you the option? What option did it give you?
Does it happen in the exact same place everytime? If it does then it is probably a driver issue. Best bet is to go to safe mode and reinstall/uninstall the main drivers.
Alternatively you could try removing any hardware thats not needed such as PCI cards to run a barebones system and see if that boots.
Thanks JB, I'll try that. I didn't see the safe mode option, and I have no idea how to get into it from startup, so I'll do some reading. :cool:
you press f8 just before the windows loading screen come's up, best way is to keep pressing f8 after the post screen
also +1 running bare bones but sounds like a software issue to me, one of my mates had a problem like this after upgrading his vga drivers
hope it helps
Ditto the video card driver problem.
When did this start happening?
Did the user change (install) anything before it screwed up?
What graphics card does he have and did he install the latest Catalyst software before this happened?
