they are already miles better than the ones shown in the highway code book.
although i think 1.6mm tread depth is not enough at all.
mine are on 1.6mm at the moment and are still good. they were a good tyre to start with though. think about those people on dodgy second hand remould tyres that are down to 1.6mm. that sort of thing really ought to be curbed
in the wet?
yeah, linglongs with 1.6mm should be outlawed... hell the tyres shouldn't be sold at all![]()
Why wouldn't you? The full 2007 report is available on the DoT website, published in September with the headline figures released in June, so I suspect in September the full report will be available.I wonder if we'll get a chance to read the full report including accident causes or not...
good in the dry but....in the wet?
Oh wait, is there supposed to be some government conspiracy here?
How long untill someone links this report with the number of safety cameras about having gone up a vast amount in the same time frame.
They will just see that number of cameras about goes up, number of deaths goes down.........
So they will only use it as a reason for even more cameras, although anyone with half a brain, can see that there is no real link between the two.
Yes I'm well aware of those links, I did just refer to them after all
Just wondering why you'd think that we wouldn't be able to see this years figures?
Probably because of the recession, people have less money available to drive around with. less cars = less accidents.
I hadnt thought of that, its amazing just how many things this could be attributed to isnt it.![]()
If i have to drive at 60mph i cant run the car in 6th gear, it has to be in 5th and the revs/distance travelled ratio is higher. the engine does more work to travel the same distance
Why people need to bang on about speed cameras, simply don't go above the speed limit, its not hard.
The road conditions are bad but they very rarely cause accidents.
