I have just started using my 42 inch plasma as my pc monitor and as i'm such a newb , I can't seem to find the ideal resolution.
my first question is what should my desktop resolution be (ideally) and what should my gaming resolution be in world of warcraft.
this is my gfx card: http://www.overclockers.co.uk/showpr...odid=GX-184-SP
this is my plasma spec:
Panasonic TH-42PX70b - 42" Widescreen Viera HD Ready Plasma TV - With Freeview
Product Features
* 1080p Digital Processing Chip-Set
* 1080p Digital Re-mastering Processor
* 3,072 Equivalent Steps of Gradation
* Max. 10,000 : 1 Contrast
* HD Optimizer
* Advanced 3D Colour management
* Motion Pattern Noise Reduction
* Sub-Pixel Controller
* VIERA Link
* 2 x HDMI Input
* High Quality Elegant Design
* PC Input
Technical Details
Tuner Integrated: Yes
DVB Digital Tuner: Yes
Tuning System: PLL synthesizer 100-position auto-search tuner
Broadcast Stereo Reception: NICAM (FM)
Fastext: 1500P Level 2.5, FASTEXT/LIST/TOP
Receiving System: PAL -I, DVB
AV-NTSC: PAL-525/60, NTSC, M-NTSC
Screen Size / Screen Aspect: 42 inch (106 cm) diagonal
Panel: G10 Progressive HD Plasma Display Panel
Number of Pixels: 786,432 (1,024 x 768) pixels
Applicable PC Signals: XGA (SXGA compressed)
Displayable Colours: Max 29 billion equavalent colours for darker part
Contrast Ratio: Max. 10,000:1
Speakers: Full-Range x 2
Audio Output: 20 W (10 W x 2), 10 percent THD
Ambience: Yes
HDMI Input: 2
PC Input: Mini D-sub 15-pin x 1 (rear)
Audio Input (for PC): RCA phono type connectors (L, R) (1 set, rear)
Component Video Input: RCA phono type x 3 (Y , PB, PR) (rear)
Audio Input (for Component Video): RCA phono type connectors (L, R) (1 set, rear)
Screen Saver: Wobbling
Multi Window: PAT
Aspect Controls: Panasonic Auto/16:9/14:9/4:3/Zoom1/Zoom2/Zoom3
Power Supply: AC 220 - 240 V, 50/60Hz
Dimensions (W x H x D): Without Stand - 1020 x 680 x 97
Product Features
* HD Optimizer
* VIERA Link
* 2 x HDMI Input
* PC Input
Technical Details
Ambience: Yes
HDMI Input: 2
Multi Window: PAT
