Spec Check
15 Aug 2003
Essex
Guys,
Decided to treat myself to a new system (my current setup is 3 years old now) so what do you think of this - for lots of video watching/storage and some casual gaming...
What PSU would you recommend?
Redone to this:
Only reason i went to 750w incase over the next year or so I decide to go SLi - assumed this would be a better option.
Is the GFX card ok? Will mainly be playing Source Games (CSS, L4D) for the most part, but likely to delve into some others (Crysis/Assassins Creed).
That card will destroy source games, as for newer games I have a 4870 on a core 2 quad (not the pc in my sig) and I can play CoD 4 at 80FPS all settings max at 1680x1050. If your gaming casually it will be more than enough
7600GT is my current card actually! :)
So you recommend the big bro of the GFX card then, no probs.
Other then that it looks ok and all compatible - i've not caught up with the hardware scene and not upgraded for 3 years - so very outdated! :(
