New build - Wont start
7 Feb 2004
Ok I am trying to build a computer at work.
Problem is I have plugged everything in and it powers up for a short time and then goes off. The monitor doesnt even come on.
The hard drive did have vista on it and it hasnt been formated, do you think that could be the problem?
Any suggestions?
Thanks
The 4 or 8 pin for cpu power installed - often gets missed.
Remove memory bar one stick and then try the other one, CMOS reset.
Just plugged in a sound cable and it goes
Beep (long)
Beem beep beep (short)
Ok found the right cmos (not very well marked)
Got as far as windows install, looking good.
Gold Star for the CMOS recommendation!
