- 25 Jun 2009
Hi I have built the following system
1 Intel Core 2 Duo, E8400, Wolfdale Core, S775, 3.0GHz, 1333MHz, 6MB Cache, 9x Multiplier
1 Asus P5Q PRO, iP45, S 775, PCI-E 2.0 (x16), DDR2 1200MHz, SATA II, SATA RAID
1 4GB (2x2GB) Corsair TwinX DDR2 XMS2, PC2-8500 (1066), 240 Pin, Non-ECC Unbuffered, CAS 5-6-6-18
1 Arctic Cooling Freezer 7 Pro - P4 up to 4.4GHz - S775 Dual/Quad Core Ready
1 1GB XFX HD 4890, PCI-E 2.0 (x16), Mem 3900MHz, GDDR5, GPU 850MHz, Cores 800, 2x DL DVI-I/HDTV
1 LG GH22LS30 AUAU 22x DVD±R, 12x DVD±DL, DVD+RW x8/-RW x6, DVD-RAM x12, SATA Black OEM
1 650W Silverstone ST65ZF-GM SLi Dual PCI-E EPS12v ATX12v v2.01 PSU
1 Enermax ECA3162-BS Phoenix Neo 5x 5.25”, 1x 3.5” (external), 4x 3.5” inc Blue LED 12cm side fan
Running under windows 7 RC 64bit
I did some research on the equipment and I think there quite good for overclocking.
Anyway question one
I upped my fsb to 422 giving 3.8Ghz cpu voltage set to 1.25v
running orthos max temp rises to 72 degrees idle is about 45/46 and when
you stop orthos it instantly drops to 55 and gradually back to 45/46 after
1-2 mins
are these temps a little high? is there anything else I should change?
question two
I have 1066Mhz ram am I right in thinking that the ram runs at the same
speed as the fsb e.g. if I ran at 400Mhz = 3.6Ghz by ram would be 400x2
Mhz = 800Mhz ? meaning I would have to overclock higher or there is no
point in getting 1066Mhz ram?
question three
What is the best way to overclock my GPU should I use the overclocking
option with the catalyst software or do it another way?
question four
I want to keep the CPU alive for a good 2 years at least what is a good
voltage/temp I should stick too?
last question five
I used the pre applied thermal paste for my freezer 7 pro is that ok?
my temp with no OC is 36 idel and 44 max
many many thanks and sorry for the amount of questions
Anyway question one
1-2 mins
question two
question three
question four
last question five
