Hi guys, first of all I have to say this forum is a fantastic source of information and pretty much everything I have learnt about oc'ing has been from reading these threads
Through the many years of using pc's, I have never had any desire to overclock at all. However, a few weeks ago I built my very first custom pc so that the missus could play sims 3 at decent setings without spending a load of cash. So I ended up with the following:
coolermaster 333 case with cm extreme 460w psu,
intel e5200 cpu (stock hsf),
gigabyte g31m-es2l mobo,
2gb generic (nanyatech) ddr2 800mhz ram,
320gb samsung hd,
radeon 4770 graphics card.
Once I got it setup, I downloaded a few demos (including crysis
) and I guess the bug bit me! I have not found it nearly as easy as some of the regulars here, but I guess practice makes perfect.
My e5200 has a VID of 1.2625 which is higher than most I've seen mentioned so I am happy enough with my current oc:
3.0ghz with 12.5 x 240 fsb, ram set at a 3.33 divider with all ram settings on auto. My vcore is 1.318 in bios showing as 1.28 in CPUID HW monitor.
Look forward to hearing any suggestions/comments
320gb samsung hd,
) and I guess the bug bit me! I have not found it nearly as easy as some of the regulars here, but I guess practice makes perfect. My e5200 has a VID of 1.2625 which is higher than most I've seen mentioned so I am happy enough with my current oc:
