Potentially looking to buy a cheap run around for weekends/holidays. The budget will be 3.5K max which will include insurance/tax/mot etc. so say 2k for the car. My insurance form a couple I have looked at is 1.5k - 2k (26 years old, 0 years NCB). Also I am probably looking to do maybe 5000 - 7500 miles a year MAX I'd say.
After a lot of reading I am beginning to narrow down a shortlist of general cars in that price range, if I could grab a quick opinion on them and any other potential recommendations that would be great.
I basically need a cheap run around, I don't need lots of performance, to date the most powerful car I have driven is a 1.8litre TD 206, so not after big engined cars. However it will be used for motorway and narrow country lanes and hills, and potentially pot holed gravel tracks, i.e heading out to camp sites, fairly remote location so may need to take a slight beating from the terrain.
It will be used to carry a modest amount of weight and potentially some large items, so estate would be ideal.
I was looking first up at the Subaru Forester, I know before you scoff it's not going to be doing any major off-road driving, but some places I go can be a bit tricky for a FWD car, especially in wet conditions. However this is a fairly minor concern.
Here is one advert on PH Now I have heard the Foresters/Legacys aren't all that bad, but with a low budget of 2K is it even worth buying something like this? My mechanical knowledge is basic, oil/water/tyres etc. I have heard a few horror stories but with everything is it a small percentage or quite a high rate of failure with these?
Next up I have heard some good things about the Volvo V40's Like this one here. Again I am very unsure on what 2K will get me in this climate. This example here sounds good to me, obviously discounting actually viewing the car, again the engines are a bit thirsty am I right in thinking but fairly solid? On avergae the mechanics of the V40 should be fairly robust? If so the low price on this is due to the 100K?
Also I hear a LOT regarding the Mondeos
I hear things about the Mk2 and Mk3 I think? Now I am unfamiliar with them and I take it you can figure out if it's a Mk2/3 etc. from the year? I assume a 2000 Ghia X 5 door estate would be a Mk2? Here is a link to AT with what seems like a fairly decent looking estate, now with the Mondeo I can imagine parts and repairs would be fairly cheap and easy to come across as opposed to the Volvo/Forester? Running costs are also in the back of my mind due to my budget. Would this kind of Mondeo be the sort of thing I should be looking at, or am I wide of the mark here with this example?
That's only three however, so rather than list them all those are the three main ones I've looked at. I have given a bit of attention to the 406 estates, but my dad has driven Peugeots so would a 406 estate be something to check out further?
Thank you
Any advice would be brilliant cheers.
Just had a look for TPFT insurance on the Volvo, coming out at under 1K, don't think it's worth going fully comp? But that might allow me to stretch my budget higher.
I hear things about the Mk2 and Mk3 I think? Now I am unfamiliar with them and I take it you can figure out if it's a Mk2/3 etc. from the year? I assume a 2000 Ghia X 5 door estate would be a Mk2? Here is a link to AT with what seems like a fairly decent looking estate, now with the Mondeo I can imagine parts and repairs would be fairly cheap and easy to come across as opposed to the Volvo/Forester? Running costs are also in the back of my mind due to my budget. Would this kind of Mondeo be the sort of thing I should be looking at, or am I wide of the mark here with this example?That's only three however, so rather than list them all those are the three main ones I've looked at. I have given a bit of attention to the 406 estates, but my dad has driven Peugeots so would a 406 estate be something to check out further?
Thank you
Any advice would be brilliant cheers.Just had a look for TPFT insurance on the Volvo, coming out at under 1K, don't think it's worth going fully comp? But that might allow me to stretch my budget higher.
