Compy just at bios logo screen :(
Caporegime
20 Oct 2002
Wish i was in a Ramen Shop Counter
Some reason my pc won't get pass the first logo screen of the bios when you turn the power on, the HD light just blinks and it does nothing....what do you guys think the problem is? It can't be windows and it's not even loading yet.
Sounds like it's struggling to initialise the HDD. If it's showing the full-screen logo, I would go into the BIOS and turn off the logo display. Then you'll be able to read the boot-up messages and see where it's hanging.
Can't get into the bios at all, just stick at the first logo, HD lights blinking. Press del to enter boos but it's not doing it
Clear the CMOS and see if you have any luck with that.
If not strip it down to a skeleton set up - cpu, gfx, 1 stick of memory (disconnect everything else) and see if you can get into the BIOS then.
If you can sit and monitor temps and then shut down and re-attach the HDD and see what happens.
EDIT: I'll leave this one to Mattus so as not to confuse things - you're in capable hands - good luck with it. (Sleep is beckoning...)
Nope, it turned it on after its been off for about 24 hours, it was stuck at the logo.
Left it since 3pm today, 9 hours later and its working.....it did ask me if i want to load safe mode though, but i just loaded windows normally.
Sounds like its getting stuck trying to detect something... I would check all connections and maybe try disconnecting everything that's not required to get into windows and see if that helps...
as he says, my recently broken ipod shuffle used to cause the same problem plus used to reset my overclock :S so yea pull out anything in your usb ports that isnt the keyboard and mouse.
